LotzCC Posted October 18, 2024 Share Posted October 18, 2024 Is there a way to mark Library items as favorites? Link to comment Share on other sites More sharing options...
DBCooper Posted October 18, 2024 Share Posted October 18, 2024 Assuming you have X16, just right click on the object in the library. Look for the "tags" menu and then add a check next to "favorites". Then hit the "apply" button. Now you can just type "favorites" into the search and they should show up. In X14, I think you could do something similar by adding search attributes. In either version, you could also create a folder in your user catalog called "favorites" and just copy items into it. Link to comment Share on other sites More sharing options...
LotzCC Posted October 18, 2024 Author Share Posted October 18, 2024 That works. Thanks. Link to comment Share on other sites More sharing options...
