jakeallen Posted October 14 Share Posted October 14 Hi everybody, I've performed a bunch of searches on this forum and tried various things, to no avail unfortunately. I have two gables that intersect in a very odd way (probably from some prior addition). For the life of me I can't get the walls to extend to the ridge boards on both sides. I've got it working on one side, but not the other (note that these are inverse views of one another, the working one is the front of the house). At one point I figured I needed to add another wall up against an existing wall, but that didn't work either. I'm attaching my project file in case it helps. Thanks very much for your time, I appreciate it. Best, Jake Here's how this looks in reality: Willo Lane Existing.plan.zip Link to comment Share on other sites More sharing options...
Solution BenPalmer Posted October 14 Solution Share Posted October 14 Extend the gable roof over that wall. An attic wall will be generated if there is a roof above it...if no roof above it, it will not be generated. Hope that helps. Willo Lane Existing.zip Link to comment Share on other sites More sharing options...
jakeallen Posted October 14 Author Share Posted October 14 @BenPalmer Brilliant, you're a life saver. Your explanation makes perfect sense, thanks so much for taking the time, I really appreciate it. Link to comment Share on other sites More sharing options...
BenPalmer Posted October 14 Share Posted October 14 12 minutes ago, jakeallen said: @BenPalmer Brilliant, you're a life saver. Your explanation makes perfect sense, thanks so much for taking the time, I really appreciate it. You're very welcome! Link to comment Share on other sites More sharing options...
