Blahbarian Posted October 11, 2024 Share Posted October 11, 2024 We need dimensions from the outside surface of the subsiding as a default. We also need the foundation to be in line with the outside of the subsiding. Is there a way to set these two as defaults? Link to comment Share on other sites More sharing options...
Solution DBCooper Posted October 11, 2024 Solution Share Posted October 11, 2024 You should be able to setup your own wall type to do this. Just take a look at the settings under wall properties. You can specify which layer is used for dimensions and foundation alignment. Link to comment Share on other sites More sharing options...
Blahbarian Posted October 14, 2024 Author Share Posted October 14, 2024 That should do it. I am new to Chief (I tried it about four months ago but just struggled hard with it, been a Softplan user since early 2000's). I REALLY want to switch to Chief because of the libraries and our interrio designer does all her renderings in Chief, they look really good. Link to comment Share on other sites More sharing options...
