Luke-A Posted 14 hours ago Share Posted 14 hours ago So I was wondering if I can curve walls at the top? So the second picture the wall is curved forward but I can’t seem to figure out how to curve it at the top. So just trying to make a slight arc. I’m inexperienced and just trying to self learn Link to comment Share on other sites More sharing options...
ericepv Posted 12 hours ago Share Posted 12 hours ago You could do this a couple of ways. Make a 3D solid from polylines to match the dimension of your wall and then make the top line a curve (you can use use a room divider to enclose your space). If you want to keep it as a wall, make a series of Kerf Cuts across the top (as per my crude example below) Link to comment Share on other sites More sharing options...
