Molding Defaults
krrbnsn
I'm using the "molding line" under corner boards in CA x16 I have several boards like the below picture that I'll be adding but they automatically come in as 1" x 1". Is there any way to change the default molding for this?
For band-boards and other accent trim like that I almost never use that molding tool. Much quicker to use a 'wall material region' which I set up as my exterior trim material. You can set default depth to 3/4 or 1 and then just draw them right on the wall you want. You can even draw them across doors and windows and they'll automatically cut themselves.
