Molding Defaults
krrbnsn
I'm using the "molding line" under corner boards in CA x16 I have several boards like the below picture that I'll be adding but they automatically come in as 1" x 1". Is there any way to change the default molding for this?
For band-boards and other accent trim like that I almost never use that molding tool. Much quicker to use a 'wall material region' which I set up as my exterior trim material. You can set default depth to 3/4 or 1 and then just draw them right on the wall you want. You can even draw them across doors and windows and they'll automatically cut themselves.
  • 2 months later...
Hi Kyle,  I'm fairly new to CA.  I'm using CA Pro 2021.  Adding horizontal trim boards to my design has been painful (the corner boards were a very simple)  Your solution seems to be the best.  Do I need to create some kind of library element or something  before I "select material" ?  Most of the online help talks about polylines, which seems to be a lot of work f762623009_ExteriorWallScreenshot.thumb.png.0e288af2118251ee19001f66f1f59f7b.pngor a simple design feature. Thanks for the help!  Paul
