jknapp Posted October 3, 2024 Share Posted October 3, 2024 (edited) When I go to change a individual wall several other walls will be changed also. Expample- I am putting a brick ledge on the front foundation wall and the whole foundation will end up with a brick ledge. Shat am I doing wrong Edited October 3, 2024 by jknapp change some spelling Link to comment Share on other sites More sharing options...
CharlesVolz Posted October 3, 2024 Share Posted October 3, 2024 Maybe you are changing the definition for wall type instead of copying the wall type, renaming it, then making changes. Or using the spray can without a license. Link to comment Share on other sites More sharing options...
jknapp Posted October 3, 2024 Author Share Posted October 3, 2024 Okay. when I go to wall type I should rename it then make the change. Got it. Thanks Charles The spray can is cheating. Link to comment Share on other sites More sharing options...
CharlesVolz Posted October 4, 2024 Share Posted October 4, 2024 15 hours ago, jknapp said: I should rename it copy and rename it Link to comment Share on other sites More sharing options...
