BenjaminZ Posted October 1, 2024 Share Posted October 1, 2024 I work for a production builder and do a lot of flipping existing plans to garage left or garage right. I do this by Edit -> Edit Area ->Edit Area (All Floors) ->Transform/Replicate ->Reflect Horizontally (Change Left <-->Right) . It seems that lately some of my electrical items swap which side of the wall they are placed on and often end up stacked on top of one another (mainly switches, TV outlets, Wall mounted lights). I have looked for a setting to change because it seems like maybe they are set to snap to a default wall side, but I do not see anything like that. Has anyone run into this or have an idea how I can keep this from happening? I have attached the plan file as it stands right after using the reflect command in case it helps. Thank you, Ben Bozeman Plan.zip Link to comment Share on other sites More sharing options...
Solution Renerabbitt Posted October 1, 2024 Solution Share Posted October 1, 2024 28 minutes ago, BenjaminZ said: I work for a production builder and do a lot of flipping existing plans to garage left or garage right. I do this by Edit -> Edit Area ->Edit Area (All Floors) ->Transform/Replicate ->Reflect Horizontally (Change Left <-->Right) . It seems that lately some of my electrical items swap which side of the wall they are placed on and often end up stacked on top of one another (mainly switches, TV outlets, Wall mounted lights). I have looked for a setting to change because it seems like maybe they are set to snap to a default wall side, but I do not see anything like that. Has anyone run into this or have an idea how I can keep this from happening? I have attached the plan file as it stands right after using the reflect command in case it helps. Thank you, Ben Bozeman Plan.zip 3.61 MB · 0 downloads We can only kind've guess at this because there is no documentation to support it but when flipping the plan the model is re-built and since many electrical symbols options classifications are designated as "mounts to wall" the symbol has to find a wall and there is some sort of internal tolerance being applied that can sometimes be a miss. If you plan on flipping a plan, you could group select like symbols and designate them as mounts to floor instead of wall before you flip and then they will not be searching for walls but rather they will keep their xy coordinates relative to a model space flip Link to comment Share on other sites More sharing options...
BenjaminZ Posted October 10, 2024 Author Share Posted October 10, 2024 I think you are right about it choosing due to it being set for wall. It seems like it moves everything to one side of the wall, almost like it's defaulting to a side after being flipped and everything just gets stacked there. It's not a huge time sink changing them manually and it it's a good time to double check any changes as well. Thanks for your help. I love your videos on YouTube and have learned quite a bit from them. Thanks again, Ben Link to comment Share on other sites More sharing options...
