Drew-PRH Posted September 28, 2024 Share Posted September 28, 2024 Good day I did not locate in the library a toe kick heater. To make things easier - I think it was anyway - I copied a 'Rectangular Ceiling Cassette'. In doing so, I changed some of the properties so the alignment would be more representative of a toe kick heater. It looks pretty close for a visual concept in Camera View. However.....In the Plan View (included) it shows the heater protruding into the room, not really under the cabinet. And in the Camera View, it appears correct. (view Included) I've also included the toe kick file to view the settings. So if someone may have a better understanding here - that would be awesome! Thanks - Drew Toe Kick Heater.calibz Link to comment Share on other sites More sharing options...
Solution scottharris Posted September 29, 2024 Solution Share Posted September 29, 2024 Drew, take a look at changing the Y origin offset of your heater. The offset will move the object into the cabinet and then look correct in plan views. I also resized the depth. Toe Kick Heater2.calibz Link to comment Share on other sites More sharing options...
Drew-PRH Posted October 9, 2024 Author Share Posted October 9, 2024 Thanks Scott, Good job. I thought I changed that Y origin. Guess not. Thanks again - have a great day!! Link to comment Share on other sites More sharing options...
