kodybaxter Posted September 23, 2024 Share Posted September 23, 2024 Hey all, I don't want to use LVL, but just regular PT. I swapped this out in room defaults but nothing changed. I couldn't find a default in the deck railing tool. Is there another setting I'm missing? I've looked at all the defaults I can, but I still haven't been able to swap out the material for the rim joist. I'd like the materials list to be able to change with each revision I make to the deck so I want to keep it automatically building Thanks for reading Link to comment Share on other sites More sharing options...
Solution GeneDavis Posted September 23, 2024 Solution Share Posted September 23, 2024 You can set that in General Framing Defaults for floor framing. There is presently no way to set rims for decks differently (width and material type) from floor framing, so unless you want to take the time to edit all deck rims in your final config to 1-1/2" P.T. lumber, you have to frame in this sequence, if floors (not decks) get engineered lumber rims. Set the floor frame rims to be 1-1/2" and P.T. lumber in the defaults, build deck framing, but do not build floor framing until after all decks are settled for size, elevation, etc. Now with decks framed, lock their framing by turning off autoframe for decks, locking their layers, and only then change the framing defaults back to however wanted for floor framing. You can now build floor framing. Link to comment Share on other sites More sharing options...
kodybaxter Posted September 24, 2024 Author Share Posted September 24, 2024 Thanks Gene! Link to comment Share on other sites More sharing options...
