SteveBenton1 Posted September 19, 2024 Share Posted September 19, 2024 I made a new " Plumbing View " In this view, I want to draw lines to all my plumbing. When I do it asks me to turn on Dimensions. When I do this, I have way to many measurements. How can I just draw a few measurement lines? Link to comment Share on other sites More sharing options...
DBCooper Posted September 21, 2024 Share Posted September 21, 2024 You need to create a new layer for your plumbing dimensions to keep them separate from the others. Then you probably want to create a new layer set with the plumbing dimensions turned on and the other dimensions turned off. Then create a new dimension default to use this new layer and call it something like "plumbing dimension defaults". Now whenever this dimension default is "active" and you draw a new dimension it will use those defaults and be on the right layer. The best way to do this is to make sure your "plumbing view" has that dimension default and your plumbing layer set as the active ones so that when you open it up everything is already setup the way you want. Here are some tech articles about creating new layers and layer sets: https://www.chiefarchitect.com/support/article/KB-03183/understanding-layers.html https://www.chiefarchitect.com/support/article/KB-00765/understanding-layer-sets.html Here is a tech article about creating and using new defaults: https://www.chiefarchitect.com/support/article/KB-03184/understanding-saved-and-active-defaults.html Here is a tech article about creating and using saved plan views: https://www.chiefarchitect.com/support/article/KB-03185/understanding-saved-plan-views.html There are also lots of training videos on all of the above. Link to comment Share on other sites More sharing options...
