Reiter Posted September 19, 2024 Share Posted September 19, 2024 I wish to create a cantilevered truss which the bottom board which sits on the top of the wall and runs all the way out to the fascia as the one in the image I have attached. I've just started a new plan after destroying my last plan with bad habits and editing I didn’t know was causing so much chaos. In my quest to not repeat another junk plan I have started over. I'm setting defaults and then testing them in a new plan to see if I can get the results I need. I've gotten to the point I want to add the roof structure and need to duplicate the cantilevered truss in the image below with a 24" overhang on a 6" pitch to match the exiting home I am adding on to. Can X15 create this truss? If it can't is the only option to manually edit a truss once I get the correct heel setting and replicate the trusses across the build or at least edit one for the Layout that the truss company will use? Link to comment Share on other sites More sharing options...
glennw Posted September 19, 2024 Share Posted September 19, 2024 As well as the Heel Height ("off plate distance"), you also need to specify Boxed Eaves. Link to comment Share on other sites More sharing options...
