GeneDavis Posted September 7, 2024 Share Posted September 7, 2024 Doing a garage/barn with a bay at one end and having issues with two things. Walls specified as "inside battens and planking" generate a set of girts on inside surface where wanted, but a copy of those girts is inserted at center of main layer, inside the 2x6 framing. Easy way to see is to look around at the 3D framing overview. Also, I have a ceiling surface I want to eliminate. The lounge room and sauna rooms both have a surface above the ceiling framing I would like to lose. File attached. Barn garage one floor only.plan Link to comment Share on other sites More sharing options...
