CJordanDesign Posted September 7, 2024 Share Posted September 7, 2024 How can I adjust the default dimension so the extension line does not touch the wall in floor plan? ie per NKBA standards. I'm using x15 Thanks, Cathy Link to comment Share on other sites More sharing options...
Solution ValleyGuy Posted September 7, 2024 Solution Share Posted September 7, 2024 2 hours ago, CJordanDesign said: How can I adjust the default dimension so the extension line does not touch the wall in floor plan? ie per NKBA standards. I'm using x15 Thanks, Cathy I'm not sure what the NKBS standard distance is, but you can adjust it through the dimension defaults under Extensions. 1 Link to comment Share on other sites More sharing options...
