stevebukowski Posted September 5, 2024 Share Posted September 5, 2024 I am working on a project with tight site constraints and I am trying to design a platform that sits within the truss structure to house the AC condensers. I initially tried just doing a 3D object to accomplish this, but it does not do what I am needing. What I want is to be able to design the trusses to create the platform within the roof structure itself. Link to comment Share on other sites More sharing options...
glennw Posted September 5, 2024 Share Posted September 5, 2024 Try this Assuming you are using auto roofs, trusses and auto framing Build a second floor In the Build Roof dbx check Ignore Top (2nd Floor) Build a room on the second floor the size you need for your platform (probably with invisible walls) Here is a very quick one I haven't got time now but read up on Attic Trusses which may do what you want 1 Link to comment Share on other sites More sharing options...
