ColePOC Posted September 5, 2024 Share Posted September 5, 2024 Wondering if anyone's encountered this issue. When I have a camera view up, and I'm deleting an object, say removing a window, or taking out an appliance, doesn't seem to matter what the object or deletion is. When I do so the camera view immediately closes, and is get a pop-up asking if I'd like to save the file. If i select save, it saves and the entire program closes. If I hit cancel, i stay in working plan view. Can be annoying. Wondering if I'm giving it a command that I'm unaware when deleting things? Link to comment Share on other sites More sharing options...
DBCooper Posted September 5, 2024 Share Posted September 5, 2024 Might be something in your plan that is causing this. Post it and someone can see if it happens for them. Link to comment Share on other sites More sharing options...
ColePOC Posted September 5, 2024 Author Share Posted September 5, 2024 Thats what I figured, but can seem to find out what that is. Plan is too large to attach apparently Link to comment Share on other sites More sharing options...
DBCooper Posted September 5, 2024 Share Posted September 5, 2024 Did you try zipping it? Or even better, try making a copy and removing stuff (like all of symbols). You might even get lucky and figure out what object is causing the problem. Link to comment Share on other sites More sharing options...
cd43521 Posted October 24, 2024 Share Posted October 24, 2024 Did you figure what was causing this.....mine does this on every plan I do Link to comment Share on other sites More sharing options...
DBCooper Posted October 24, 2024 Share Posted October 24, 2024 I don't know if or how ColePOC solved their problem but it it's happening for you on every plan than it sounds more like a system/install issue. You probably need to contact tech support. Link to comment Share on other sites More sharing options...
cd43521 Posted October 24, 2024 Share Posted October 24, 2024 DB thank you for info I will do that Link to comment Share on other sites More sharing options...
