Grainy Glass and Metal
cbdesign
Hello! I am struggling with this PBR, the metal and glass remain grainy no matter what I do. Other materials seem okay to me. I've attached a rendered image and an image showing the PBR settings I used. Any help would be appreciated!
Thank you!
Loren
Chief Architect Premier X15
Intel(R) Core(TM) i7-10700F CPU @ 2.90GHz
NVIDIA GeForce RTX 2060 SUPER
There could be quite a few other factors that might be adjusted for improvements, but as a starting point I'd suggest lowering the exposure to 0.35 and increasing the brightness to 20.
Sample rate should be able to be reduced to 100. Next, inspect the backdrop and its intensity (try 9000), sunlight settings (100,000 for daytime scene), and the light set in use for that camera, followed by lighting adjustments. Just creating / using a light set can have a drastic impact.
After that, start examining some materials, like glass and emissive light bulb materials.
