Synergy Posted August 23, 2024 Share Posted August 23, 2024 Hi, Have an issue where the internal pocket part of the wall/door is creating a hole through a wall. See attached. We have tried changing the door thickness and wall thickness and other settings but no difference. Is there a setting somewhere that I am missing to fix this? Seems like it would be a simple thing to fix but can't figure it out without using a solid to fill in the wall. Link to comment Share on other sites More sharing options...
DBCooper Posted August 23, 2024 Share Posted August 23, 2024 My best guess is that your wall type only has a single layer. When the program cuts a pocket hole for the door, it then removes everything. Try using a different wall type or adding a couple of thin layers to both sides of the wall type. Link to comment Share on other sites More sharing options...
Solution Synergy Posted August 23, 2024 Author Solution Share Posted August 23, 2024 Thanks for that. I did try that and it didn't work but it got me thinking and found the solution. The wall type def > select the layer > material properties - the framing box was ticked. Untick the box and all good. Cheers. Link to comment Share on other sites More sharing options...
Synergy Posted August 23, 2024 Author Share Posted August 23, 2024 BTW @DBCooperyou were partly correct with single layer wall. By adding layers that would help as well, as long as you don't tick the framing box for the exterior wall layers. 1 Link to comment Share on other sites More sharing options...
