mtldesigns Posted August 22, 2024 Share Posted August 22, 2024 Ok, this should be pretty simple and I swear I have done this before. The client has a hideous 1" thk. countertop, my default is 1.5". When I change the thickness to 1", the sink does NOT move up accordingly. Even when I select just the sink (tab) and just get the sink dbx, changing the elevation doesn't do anything. Am I looking right at it here on the specifications and just not seeing it? Link to comment Share on other sites More sharing options...
mtldesigns Posted August 22, 2024 Author Share Posted August 22, 2024 never mind... looked at this for 30 minutes.. sent this OP then found it. I adjust the height is the 3D tab in it's z position. Link to comment Share on other sites More sharing options...
