ChiefUserKatie Posted August 21, 2024 Share Posted August 21, 2024 Hello, does anyone know a way to make my default elevation rendering technique to be 'Standard' with the 'hand drawn lines on top' box checked? I've attached a snip of the settings I would like to make my default whenever I create a new elevation. When I click the wrench to set this as my default elevation, it will make my default rendering technique 'Standard', but I am unable to keep the 'Hand drawn lines on top' box checked. I appreciate any help on this! Link to comment Share on other sites More sharing options...
Solution DBCooper Posted August 21, 2024 Solution Share Posted August 21, 2024 Try going to "default settings", then "3d view defaults", and then "rendering techniques". This will change it for all views using standard though, not just elevations. I don't know if there is a way to just change the default for elevations but I couldn't find one. Link to comment Share on other sites More sharing options...
ChiefUserKatie Posted August 26, 2024 Author Share Posted August 26, 2024 Thanks @DBCooper, that's a big help. I wish you could specify that different setting for elevations vs 3D views, but this will still be a help in my drawing set up process. Thanks! Link to comment Share on other sites More sharing options...
