ChiefLooHoo Posted August 20, 2024 Share Posted August 20, 2024 If one deletes an elevation, now the number skips one number, so I am missing elevation 5. Is there a way to renumber so that all the elevation numbers are there. In other words move up the numbers after the one that was deleted. Link to comment Share on other sites More sharing options...
DBCooper Posted August 21, 2024 Share Posted August 21, 2024 You can just open the camera dialog and change the camera name to be whatever you want (such as Elevation 5). You can also edit the callout label to show whatever you want (such as E5). Link to comment Share on other sites More sharing options...
ChiefLooHoo Posted August 21, 2024 Author Share Posted August 21, 2024 Hmm i thought that too, i tried with the elevation symbol but will try with camera? I will check again. thank you for responding! I will try and check that out! Link to comment Share on other sites More sharing options...
