Jake1976 Posted August 10, 2024 Share Posted August 10, 2024 Hello Chief pros. Quick question, I'm using the rail function "Post to Beam" which is awesome, but I can't find the setting (if it exists) to NOT have the newels at the stair go to the beam. Is there a setting somewhere that I'm missing? Image attached. Link to comment Share on other sites More sharing options...
DBCooper Posted August 10, 2024 Share Posted August 10, 2024 If you are using X16 you can just delete those posts and then place shorter ones manually. In older versions, I think you would have to break the wall into 3 pieces and then you should be able to turn off the post at the start and end. 1 Link to comment Share on other sites More sharing options...
