JKEdmo Posted August 8, 2024 Share Posted August 8, 2024 I prefer to use the Single-Pole light switch in all cases. I manually label 3- and 4-way wall switches when they occur. This is so I can neatly add other remarks, such as "D" for dimmer: My question -- Anybody know how to turn off the automatic feature from the get go and keep it off? When I go to Defaults / Electrical Service Specification / Options, this feature is greyed out... Thanks again, Jim Link to comment Share on other sites More sharing options...
proformacon Posted August 9, 2024 Share Posted August 9, 2024 Bit of a work around but this works. Open your template, add a switch to a wall, open that switch, options, uncheck change automatic. Then right click the switch and click Set As Default. Then save your template. Link to comment Share on other sites More sharing options...
JKEdmo Posted August 9, 2024 Author Share Posted August 9, 2024 27 minutes ago, proformacon said: Bit of a work around but this works. Thanks Doug. I'll look into this. Jim Link to comment Share on other sites More sharing options...
