half wall caps sticking out on roof cut half walls
KENTHOMAS
I built a second story and then pulled the roof down to one and a half inches above the floor elevation to sit on plate attached to the floor. And then run a half wall, parallel with the rafters and the wall was cut by the roof, but the cap on the half wall sticks out through the roof. It isn't cut with the wall. Why? and the program generated a gap in the wall.?
I'm using Chief Architect Premier X16 for MAC. I temporarily solved the problem by just deleting the wall caps, but there's gotta be a better solution. As far as the gap, I just pulled a half wall across, and it was there. Thanks for responding.
