SkyTree-Greg Posted July 28, 2024 Share Posted July 28, 2024 Trying to figure out why the program is applying 1/2" x 1.5" furring to my interior walls... Walls type defined as the original "Interior-4 wall" that ships with the program. Wall type definition shows 1/2" drywall / 3 1/2" framing / 1/2" drywall as the layers with the total thickness at 4 1/2" Furring displays in any framing view and wall thickness measured is 4" (furring & framing) Displays in plan view with drywall one side, and furring on the other side and wall thickness is 4 1/2" (drywall / 3.5" framing / furring) If I build 'framing, Wall', it appears the furring (in plan view) is shown as a line that matches the drywall line on the other side, but the furring sticks out funny at my 45 deg wall corners If I take camera views before 'build framing', the walls appear normal When I build framing, and then take a camera view, only a sheet of drywall appears, with a gap where the framing and drywall should reside. (molding, electrical, etc are hanging in space) This is for a remodel, and I have the rest of the house drawn making the file too big to send here. I will delete the existing house and just leave the addition and upload here. The program is doing this to all interior walls. *** When I deleted everything extraneous to get the file small enough, it shows the drywall in camera view but still has furring sticking out at the 45 deg corners (wall other side of sink) As a side note, if anyone knows a good way to display trusses for flat roofs with parapets, I'm all ears. I've figured out a way to get the roofing to display correctly, but trying to get trusses to work with slope and parapet walls is alluding me. Thanks Greg SkyTreeAZ LLC Running Windows 10 Home Ver. 10.0.19045 Build 19045 GEOForce RTX 3080 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz 32.0 GB (31.8 GB usable) 64-bit operating system, x64-based processor Phillips Remodel FURRING ISSUE.plan Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted July 28, 2024 Solution Share Posted July 28, 2024 27 minutes ago, SkyTree-Greg said: Trying to figure out why the program is applying 1/2" x 1.5" furring to my interior walls... It actually NOT ...... you have set the Drywall on that side to be a "Framing Material", and chief is cutting out holes ..... just uncheck the framing box.... you might want to Add a Sig. , so People know what Version you are using etc...this sometimes matters.... here's how https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 M. Link to comment Share on other sites More sharing options...
SkyTree-Greg Posted July 29, 2024 Author Share Posted July 29, 2024 Thank you. That did the trick. I have no idea how that was checked, nor that that section would make the program behave that way. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 29, 2024 Share Posted July 29, 2024 3 minutes ago, SkyTree-Greg said: Thank you. That did the trick. I have no idea how that was checked, nor that that section would make the program behave that way. Happy to help don't forget your Sig, then you wont need to post your info with every question eg put this in your Sig. with the version you are using otherwise people will assume your are using the latest eg X16 currently. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 Windows 10 Home Ver. 10.0.19045 Build 19045 GEOForce RTX 3080 11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz 3.60 GHz 32.0 GB (31.8 GB usable) 64-bit operating system, x64-based processor Link to comment Share on other sites More sharing options...
