KirillP Posted July 21, 2024 Share Posted July 21, 2024 Hello, How do people design large multipurpose spaces? Maybe I'm just doing it wrong. I have kitchen, dining and living space as one U-shaped area and leg of the U is a "separate" room of type kitchen, because it has different ceiling height and generally it's useful to see the kitchen "separately" when working on the plan. As a consequence of this I can't create a unified floor pattern, see the screenshot. The highlighted area is where the kitchen/dining boundary is. The boundary is purely logical (on the floor, ceiling is different). Is it possible to join the floors without joining the rooms? Thanks for all the ideas Link to comment Share on other sites More sharing options...
Solution DBCooper Posted July 21, 2024 Solution Share Posted July 21, 2024 You could try this: - Select one room. - Use the "expand room polyline tool". - Use the "make room polyline tool". - Use the "convert polyline" tool. - Make it a "material region". It should have a continuous material/pattern. You can adjust the material properties if you want to change the angle or offsets. Link to comment Share on other sites More sharing options...
KirillP Posted July 21, 2024 Author Share Posted July 21, 2024 Wow, that worked, thanks a lot! Link to comment Share on other sites More sharing options...
