SkyTree-Greg Posted July 18, 2024 Share Posted July 18, 2024 Using X15 version for this plan. My cross section/elevations both normal and back-clipped will not display the monolithic slab. It will show up on 3D full overview and on foundation overview. The footings under the columns in the back do show up in elevation views, but do not display on the foundation level. I have foundation, footings, walls foundation, CAD foundation all checked in Active Layer Display. If I start a new plan of a simple room with monolithic footing in ver X15, that foundation as well doesn't display. Changing the foundation to Footing and Stem, it will display. If I jump to X16 and do a simple house with monolithic footing, the foundation will display in cross sections and elevations. Can't upload file as it's 23MB and is too large for ChiefTalk Link to comment Share on other sites More sharing options...
SkyTree-Greg Posted July 18, 2024 Author Share Posted July 18, 2024 As an update... If I rebuild the foundation as Stem and Wall, it displays normally in Elevations and Cross sections. Rebuilding the foundation and changing it back to monolithic, it will build the foundation, I can see it on floor level 0, see it in floor perspective, but won't display on cross sections and elevations. Link to comment Share on other sites More sharing options...
Solution robdyck Posted July 18, 2024 Solution Share Posted July 18, 2024 Check for the display of this layer: Slabs Link to comment Share on other sites More sharing options...
SkyTree-Greg Posted July 18, 2024 Author Share Posted July 18, 2024 35 minutes ago, robdyck said: Check for the display of this layer: Slabs Thank you sir.. that did the trick. Don't know why Chief treats a monolithic differently in layers, but it worked. 1 Link to comment Share on other sites More sharing options...
