Drawing Quonset Hut Elevation Renderings and full Blueprints - Construction Docs.
Jeff_Bilt
On 7/12/2024 at 1:04 AM, ChiefUserFarzan said:
sir, quonset hut usually replace the exterior wall with roof and chief can handle it very well.
hence, i am super interested to discuss further on your requirements.
Thank you
I have a brand new Quonset hut that’s 60’ wide and 66’ long that’s sitting on pallets right now on my land in Eastern Tennessee mountains and I’m looking to put a full basement under it. The basement ceiling height needs to be minimum 12’ from concrete slab to bottom of floor trusses. Walls will be poured concrete reinforced with rebar and fiber. It’s a walk out basement on one end with an overhead garage door and pedestrian door and a few windows. From grade up on first floor there will be the same poured in place stem walls going up 6’ and most likely will need poured side supports to support the metal Quonset hut. The floor trusses need to be engineered to support 2 floors. There will be a loft above the first floor. Does this sound like something you can help with?
sir, clearly understood and yes, can assist with all your requirements. could you please share related docs like image, sketch or any available project docs etc over email to go through and discuss further. my email farzan.wadud@gmail.com
Thank You
