ttoohey Posted July 6, 2024 Share Posted July 6, 2024 when i select dollhouse view, the roof framing shows. How do I get it so the roof framing does not show? Link to comment Share on other sites More sharing options...
Chopsaw Posted July 6, 2024 Share Posted July 6, 2024 Interesting view but I assume that is not what you were expecting. Turn off the appropriate layers in your camera view. I find the easiest way to do this is to have your Active Layer Display Options open and select the object you want to turn off (likely on the "Framing, Roof Rafters" layer by default and then just turn it off. There is a special layer hider tool but if you are just learning that will not teach you anything. Link to comment Share on other sites More sharing options...
ttoohey Posted July 14, 2024 Author Share Posted July 14, 2024 Thank you! Link to comment Share on other sites More sharing options...
