Wall issue at soffit
Can anybody tell me what I'm doing wrong with a wall in my plan? I have a fence wall that is projecting itself up to the underside of a roof soffit. There is a portion of wall that appears on the underside of the soffit, and I just can't figure out what's causing it.
I've attached the plan file that has a saved camera and also the problem area clouded. I've also attached an image where I've circled the problem area.
I know there are many out there who are smarter than me and I'd appreciate any help.
Thanks very much.
Adelman Residence.zip
I see you don't have those block fences at the default bottom height. If you're okay with manually adjusting the wall top / bottom, then a quick fix is to uncheck railing and manually adjust the top of those walls. A couple of cad lines in section view are helpful before doing this, just to locate the current top of wall. Then, uncheck 'use room ceiling finish' for the roof plane.
