C4Adrafting Posted Thursday at 03:41 PM Share Posted Thursday at 03:41 PM Can anybody tell me what I'm doing wrong with a wall in my plan? I have a fence wall that is projecting itself up to the underside of a roof soffit. There is a portion of wall that appears on the underside of the soffit, and I just can't figure out what's causing it. I've attached the plan file that has a saved camera and also the problem area clouded. I've also attached an image where I've circled the problem area. I know there are many out there who are smarter than me and I'd appreciate any help. Thanks very much. Adelman Residence.zip Link to comment Share on other sites More sharing options...
robdyck Posted Thursday at 05:16 PM Share Posted Thursday at 05:16 PM I see you don't have those block fences at the default bottom height. If you're okay with manually adjusting the wall top / bottom, then a quick fix is to uncheck railing and manually adjust the top of those walls. A couple of cad lines in section view are helpful before doing this, just to locate the current top of wall. Then, uncheck 'use room ceiling finish' for the roof plane. Link to comment Share on other sites More sharing options...
C4Adrafting Posted Thursday at 08:57 PM Author Share Posted Thursday at 08:57 PM Thanks very much! I'll give it a try. Link to comment Share on other sites More sharing options...
