Cadwork22 Posted June 29, 2024 Share Posted June 29, 2024 I'm attaching a layout file. I colored coded the rooms in the floorplan, however this carried over into the electrical and mechanical. Is there any way to just keep the color coding to the floor plan??? KATHY (3).zipFetching info... Link to comment Share on other sites More sharing options...
VHampton Posted June 30, 2024 Share Posted June 30, 2024 Question... what layer is the color coding on? A.) If the color coding was made with room fill... then that's easy enough to toggle on and off. The layer is "Rooms". B.) If the colors were made with poly-lines (CAD, Default) then you may not want to turn off the primary CAD layer. Place them all on a new layer. Call it "CAD, Color Code" or whatever suits. Turn off that layer for the MEP layout. Link to comment Share on other sites More sharing options...
