raltd9245 Posted June 28, 2024 Share Posted June 28, 2024 How Come chiefs roof styles does not include a "FLAT ROOF" Link to comment Share on other sites More sharing options...
raltd9245 Posted June 28, 2024 Author Share Posted June 28, 2024 like this where is the flat roof example!!!! Link to comment Share on other sites More sharing options...
Solution raltd9245 Posted June 28, 2024 Author Solution Share Posted June 28, 2024 Go to Help and type in ""build a flat roof" and chief gives U How to draw a cross section/Elevation Views. Link to comment Share on other sites More sharing options...
raltd9245 Posted June 28, 2024 Author Share Posted June 28, 2024 Go to Help and type in ""build a flat roof" and chief gives U How to draw a cross section/Elevation Views. Link to comment Share on other sites More sharing options...
mthd97 Posted June 29, 2024 Share Posted June 29, 2024 Shed roof (mono pitch) or with zero degrees is the same as a flat roof. Either way you still need to get the water to drain off in some way. Link to comment Share on other sites More sharing options...
