Ed_Orum Posted June 28, 2024 Share Posted June 28, 2024 In X15, when I created a CAD block, then added it to the User Library, it would show up in the bottom of the tree. From there I could re-name it, then click on it and select "move to folder". Now, in X16, the "Move to folder" option is gone. Is it just my program, or did X16 take a step backwards? Is there a different way to move an item from one folder to another without cutting it from the first folder, then pasting it to the second folder? Thanks in advance. Lane Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 28, 2024 Share Posted June 28, 2024 The Help files say that the Move to Folder tool was simply renamed Create Link, but it doesn't seem to work like the old tool and the Help files are still describing Move to Folder as one of the available tools. I'm not sure if its broken or if they intended to change the functionality. That beings said, is Cut/Paste not just as fast? You can also click and drag to a new location in case you didn't know that. 1 Link to comment Share on other sites More sharing options...
Ed_Orum Posted June 29, 2024 Author Share Posted June 29, 2024 Thanks. I think this bears out the old adage "If it ain't broke, don't fix it". Lane Link to comment Share on other sites More sharing options...
