Jake1976 Posted June 23, 2024 Share Posted June 23, 2024 About 6 months ago, I discovered drawings sheet setup (File>Print>Drawing Sheet Setup) which is extremely helpful to see how line weights and line type scale will appear. However, I thought that the Drawing Sheet Setup was linked and saved to the view. In fact, it says that it is in the Help files. However, it appears that it's global across all views in the file. Perhaps I'm missing something. Can anyone let me know if there is a setting somewhere that allows to be tied and saved to the view? I did find a work around. If I have the layout file open and then I open the view from the sheet layout, then chief does change the scale in the drawing sheet setup to the scale that is set in the layout. However, it would be nice, if we didn't have to open the view from the sheet in order for the line weights and line type scales to look correct regardless. here's a screencapture video if this is confusing. https://capture.dropbox.com/fkCEVWdrWvvBZGN4 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 23, 2024 Share Posted June 23, 2024 If the scale is included in the Layer Set name the attached macro will display the scale accurately in the plan view. Simply put it in a text box in the plan view. layer_set_Drawing_Scale.json Link to comment Share on other sites More sharing options...
