Josh_Thiessen Posted June 21 Share Posted June 21 Could someone help me out with this error? I'm trying to build a door partly into the foundation wall and partly into the main floor exterior wall, and I'm getting this mess no matter how I do it. What I've done here is to simply place the door into the main floor wall, then adjust the wall to bottom of door height to a negative number to place it level with the terrain. I hope someone can make sense of this. Link to comment Share on other sites More sharing options...
DBCooper Posted June 22 Share Posted June 22 See if these help/training materials on "split level" entries help. If not, then post your plan and someone could probably give you some better suggestions. https://www.chiefarchitect.com/videos/watch/323/creating-a-split-entry.html?playlist=88 https://www.chiefarchitect.com/support/article/KB-00587/creating-a-split-level-entry-or-foyer-with-a-landing.html Link to comment Share on other sites More sharing options...
