Josh_Thiessen Posted June 21, 2024 Share Posted June 21, 2024 Could someone help me out with this error? I'm trying to build a door partly into the foundation wall and partly into the main floor exterior wall, and I'm getting this mess no matter how I do it. What I've done here is to simply place the door into the main floor wall, then adjust the wall to bottom of door height to a negative number to place it level with the terrain. I hope someone can make sense of this. Link to comment Share on other sites More sharing options...
DBCooper Posted June 22, 2024 Share Posted June 22, 2024 See if these help/training materials on "split level" entries help. If not, then post your plan and someone could probably give you some better suggestions. https://www.chiefarchitect.com/videos/watch/323/creating-a-split-entry.html?playlist=88 https://www.chiefarchitect.com/support/article/KB-00587/creating-a-split-level-entry-or-foyer-with-a-landing.html Link to comment Share on other sites More sharing options...
