Drew-PRH Posted June 16, 2024 Share Posted June 16, 2024 Good day, I drew in 3D Solid a custom corner board, replicating the EZ Trim EZ31 - extruded Aluminum Outside Corner. I can manually place the corner 'on top' of the corner - kinda - however by this method it will not pull back the siding material on either side (which I figured). See the image included which shows the siding material needs to be pulled back slightly from the corners for the aluminum outside reveal to show. For the material - within the - Open Object / Layers. The Default Layer is "Corner Boards". The Drawing Group is "24 - Corner Board/Quoin". I've also tried place the default corner board, and then try 'Replace Molding'. However that would not pull up my material in this manner. So I suspect I don't have one of the properties correct. Might someone know how to remedy this to use this new created material. Thank you!! - Drew Link to comment Share on other sites More sharing options...
Solution glennw Posted June 16, 2024 Solution Share Posted June 16, 2024 Drew, You may be able to use a Wall Material Region with Cut Finish Layers from Parent Object and then locate your corner molding over that. The attached pic is just to demonstrate the technique - you would need to resize and locate as required. 1 Link to comment Share on other sites More sharing options...
Drew-PRH Posted June 18, 2024 Author Share Posted June 18, 2024 Thanks Glenn, That worked out great! Good job! - Drew Link to comment Share on other sites More sharing options...
