ADAMS_COMPANY Posted June 5, 2024 Share Posted June 5, 2024 I have 3 major issues I need help with: I drew in a tub surround that shows up in 3D views and on the floorplan, but does not show up in the elevation view. Part of the wall above the shower material disappears in elevation mode, but when I select the wall, the full area (including the part that doesn't appear correctly) is highlighted. Is there a way to keep materials visible in a vector view? Thank you in advance!! Help!! Link to comment Share on other sites More sharing options...
DBCooper Posted June 5, 2024 Share Posted June 5, 2024 1. My guess is that your elevation view is using a different layer set than the other camera views and the layer is turned off in that set. 2. Not sure. Maybe post the plan? 3. I am definitely seeing materials in your pictures above (otherwise you wouldn't see anything). Maybe you want to see the textures instead of the patterns? Or do you want to see both? By default vector views only show patterns but you could use a different render technique that will show you the textures instead and if you want to see both you can add lines on top of the textures. Here is a basic video about render techniques to get you started: https://www.chiefarchitect.com/videos/watch/6150/rendering-techniques.html Link to comment Share on other sites More sharing options...
