DeeAus Posted June 1, 2024 Share Posted June 1, 2024 Hi, Sorry, I am a newbie. Aplogies for this basic question. I am trying to display the internal width and length of my room in the room label. For some reason it is dipslaying 26mm less in every room dimension. Please see the attahed screenshot. The room internal width and length is 3500mm X 3500mm. But the room label is displaying 3474mm x 3474mm. How can I make the room label also display 3500mm X 3500mm (and what is that 3474mm x 3474mm measurement). Appreciate any advice. Many thanks Link to comment Share on other sites More sharing options...
DeeAus Posted June 1, 2024 Author Share Posted June 1, 2024 Nevermind... found where the problem is. It's the temporary dimension setting. Sorry! Link to comment Share on other sites More sharing options...
DBCooper Posted June 1, 2024 Share Posted June 1, 2024 Glad you found it. In your pictures above, it's easy to see that your dimension line is going to the main layer of the wall instead of going to the surface. The room interior dimensions would always go to the surface so that is what the difference is. Changing what your temporary dimensions are locating is one way of solving this problem. You can also change the locate settings for your interior dimensions in your dimension defaults if you always want to have them going to the wall surfaces. You can also just draw a manual dimension and then move the end from the main layer to the surface. 1 Link to comment Share on other sites More sharing options...
DeeAus Posted June 2, 2024 Author Share Posted June 2, 2024 Thanks so much for your advice, DBCooper Link to comment Share on other sites More sharing options...
