ccollin Posted May 29, 2024 Share Posted May 29, 2024 Hello all, I have created custom lines to produce an HVAC ductwork layout. I've used a dash with an arrow as text to indicate direction. However, for some reason when I create the last leg of a run sometimes it reverses the direction of the arrows and they are going the opposite directions in the same line. I've tried turning the connect CAD segments on and off and it does the same thing either way. I've also tried setting the individual line segment to the opposite line. It just reversed both of them. Any ideas? Thanks! Link to comment Share on other sites More sharing options...
TeaTime Posted May 29, 2024 Share Posted May 29, 2024 Text likes to align Right and Down. So even if you try to get fancy with a ► character or something, you'll still see something like Best off the cuff solution would be to create two line styles, use Disconnect Selected Edge and alternate styles as needed: Link to comment Share on other sites More sharing options...
ccollin Posted May 29, 2024 Author Share Posted May 29, 2024 Oh perfect. Thanks. I did try that already, but I guess I forgot to turn the connection off. Works now Link to comment Share on other sites More sharing options...
