railing cuts stucco
SHCanada2
is there some setting to stop this? It does not do it at the other end of the railing. (its a pony wall underneath, but if I make it just a railing it does the same thing, just narrower)
I tried the edit intersections tool, no luck. I tried changing the one wall to be the through wall, no difference
If I delete the wall and then redraw, it then looks normal
maybe  it was a victim of that wall being reversed earlier, and then I use the reverse tool to make the wall look correct and then this happens.
of course, its not repeatable: If I reverse the new wall I just drew, and then reverse again, it doesnt happen. ...maybe it was something else...
On something like a railing you can always check that it is a partition wall in the wall dbx and that can make it disappear.  I'm guessing you have something else going on and I wouldn't make this my go to method but it can fix your problem.
