lsandine Posted May 1 Share Posted May 1 Software X15, room type is balcony, interior wall placement of outlet is added as WP. I changed room type to great room and the outlets are placed properly. Having an issue with loft (3rd story) floor wall connections. The bedroom wall is not extended to the ceiling. The loft balcony wall is not lined up properly. This issue became a bit more pronounced after I changed the room type from balcony to great room. This house doesn't have an attic. I don't recall when and why I configured that way. Thank you Link to comment Share on other sites More sharing options...
lsandine Posted May 1 Author Share Posted May 1 My plan file is 47MB so I am not able to attach. How are these typically shared in this case? Google drive or dropbox link etc? Link to comment Share on other sites More sharing options...
Mark3D Posted May 1 Share Posted May 1 With the wall not going to the ceiling, open wall structure tab select default top height As for sharing the file google drive works for me you just need to set sharing to anyone with link Link to comment Share on other sites More sharing options...
