chiefuserJason94 Posted April 13, 2024 Share Posted April 13, 2024 How does one go about creating kitchen appliances that have panels to match cabinets? Link to comment Share on other sites More sharing options...
MarkMc Posted April 13, 2024 Share Posted April 13, 2024 1 hour ago, chiefuserJason94 said: creating kitchen appliances that have panels Depending on your needs. Simplest for just the look; use cabinets and rename them. You will need to adjust reveal and/or incorporate small openings. If you want them in a cabinet schedule for ordering you can float door panels and block. Or Use a cabinet for each panel which is easier to place, schedule can include width an height but depth will be wrong. Or A combination where you make from cabinets, not include in schedule, for plan and 3D, and also float panels somewhere out of the way on a separate layer to include in schedule. Note. Flush inset paneled can be complicated if you need completely accurate image with all parts. Instead they're easy enough to approximate the look and include a cad detail. For any.. Start in a new plan. Save stages by copy/ paste. Keep a folder to save those plans in for the future. Also save final results to folder(s) in library. Look into saving results as style palettes depending on method used. Link to comment Share on other sites More sharing options...
