Walls...
nhenning
Go to solution Solved by TeaTime,
  • Solution
So you drew the existing walls, set them to a "Walls, Existing" layer, then hid it? Those walls are still there. You don't want hidden walls, they're still there and affecting the model. You'll be better off drawing them with CAD or using some form of mask. Check out their resources https://www.chiefarchitect.com/search/?default_tab=all&q=as+built
