MissJane Posted March 26, 2024 Share Posted March 26, 2024 Hi all, I am fairy new using Chief Architect. Please pardon my question if it's already been asked as I can't seem to locate an answer for my searches. When you include your client info, your business info, drawing info etc in the layout label, it's usually vertically on the right. Is it possible to customize it to be at the bottom of the print out page, horizontally? Is there a quick setting that can be set so it's easy to toggle back and forth with horizontal or vertical consideration? Also, how can you edit or customize the blue grid inside the layout label area? Thank you! Link to comment Share on other sites More sharing options...
rlackore Posted March 26, 2024 Share Posted March 26, 2024 You can fully customize your title block by editing the content of the Layout Page that is used as the Page Template. Download the reference manual for your version of Chief, and read the chapter on Layouts, paying particular attention to the sections on Layout Page Management, Layout Page Information, and Layout Page and Revision Tables. Link to comment Share on other sites More sharing options...
MissJane Posted March 26, 2024 Author Share Posted March 26, 2024 Thank you! I found the guide and will take a deeper dive... Link to comment Share on other sites More sharing options...
