ZackEller Posted March 21, 2024 Share Posted March 21, 2024 I have a question regarding changing the wall height in the 3D window. I realize that this question already asked when CAX11 was the current version. I watched a few videos on the new features in CAX11,12,13 & 14 from Chief Experts and saw Dan edit a wall in 3D. I’m not sure which version he was demonstrating but I think he said that “when you edit a wall height, the room definition changes and you can no longer auto rebuild the room” or something to that effect ??? I haven’t been able to find that video again and it may have been on the new features in CAX11 ??? Does anyone know what this is about or what version he may have been demonstrating ? It’s annoying not being able to find that resource again. I have conducted several tests in CAX10 and X15 trial with adjusting a wall up past the default ceiling height in 3D (single story house) and I can’t see that affecting the room definitions ??? Could be a special case or in a two story dwelling maybe ??? Link to comment Share on other sites More sharing options...
ZackEller Posted March 21, 2024 Author Share Posted March 21, 2024 On 3/21/2024 at 11:43 AM, ZackEller said: I have a question regarding changing the wall height in the 3D window. I realize that this question above was asked when CAX11 was the current version. I watched a few videos on the new features in CAX11,12,13 & 14 from Chief Experts and saw Dan edit a wall in 3D. I’m not sure which version he was demonstrating but I think he said that “when you edit a wall height, the room definition changes and you can no longer auto rebuild the room” or something to that effect ??? I haven’t been able to find that video again and it may have been on the new features in CAX11 ??? Does anyone know what this is about or what version he may have been demonstrating ? It’s annoying not being able to find that resource again. I have conducted several tests in CAX10 and X15 trial with adjusting a wall up past the default ceiling height in 3D (single story house) and I can’t see that affecting the room definitions ??? Could be a special case or in a two story dwelling maybe ???https://stripesroofing.com/ Expand Thank you for any help in advance. Link to comment Share on other sites More sharing options...
robdyck Posted March 21, 2024 Share Posted March 21, 2024 Changing the top or the bottom of the wall has no effect on any Room Definition. Rather, Rooms control the default top and bottom of walls...so you just need to keep in mind that when you manually change the top or bottom of a wall, that editing action will now prevent a wall from rebuilding correctly if/when a room height or floor height is changed. By 'height' I am of course referring to the vertical distance between a floor and ceiling / roof. Does that make sense? For example, let's assume you have a house with an 8' ceiling. Then, for whatever reason, you manually drag the top of a wall up, let's say 7". Next week, your client informs you that they actually want a 10 ceiling on that floor level. The wall that was adjusted manually will not build to the correct height...it would now be 14" too short! Link to comment Share on other sites More sharing options...
