DHerb2014 Posted March 8, 2024 Share Posted March 8, 2024 Created and modeled a 3D truss roof into a custom profile. Traced over the attached PDF and converted it into a 3D object. What I can't figure out (in my small brain) is how to move the image so that it can be imported into the floor plan as a "flat roof"? Attaching a section of what it looks like, a Plan file, and Camera view of what it looks like currently. In Section view, it looks great. When you take a camera shot, it's 90 degrees vertical...? What is the procedure for creating this block as a flat image? This is a tricky one CUSTOM ROOF MODEL.plan Link to comment Share on other sites More sharing options...
DHerb2014 Posted March 8, 2024 Author Share Posted March 8, 2024 The image of the sky is the Camera view looking at the model that I made. It's supposed to be flat with the flat portion facing up toward the sky. The way the block sits currently, is vertically-oriented. The model that I traced over was the PDF section with the man standing. I traced over the outer portions of the truss-roof, and then converted it with "Convert to Polyline" tool as a slab. I gave it a 35' depth. I was trying to extrude the object, but it was converted to a vertical block, and I need it to be a flat block sitting on top of a wall (shown in PDF section). All I'm trying to do is lay the block flat from its current vertical position. Link to comment Share on other sites More sharing options...
RL-inc Posted March 8, 2024 Share Posted March 8, 2024 I drew the original shape in plan view but as it would be constructed from the top at a width of 1 1/2" or whatever the depth of the truss chords are- Then I took an elevation view of that 3d solid a brought in a CAD detail of the truss shape you were after and used it to modify from that perspective. Link to comment Share on other sites More sharing options...
RL-inc Posted March 8, 2024 Share Posted March 8, 2024 Basically similar to what eric said I believe Link to comment Share on other sites More sharing options...
DHerb2014 Posted March 8, 2024 Author Share Posted March 8, 2024 Many thanks guys, as I did Rob L. said, and it works perfect! Able to rotate and move around easily. YOU GUYS ROCK! Link to comment Share on other sites More sharing options...
