DIYJon Posted February 27, 2024 Share Posted February 27, 2024 (edited) I've watched the video on overlaying a remodel on an as-built plan to visualize the changes, but I think I might be stuck on one point. I have drawn out my current residence. Some of the existing walls are block wall with 1" furring strips between 1/2" drywall with no insulation. I'm furring out those walls to have 2X3 studs and foam insulation. On my as-built plan, will I need to create a new layer just for that wall (i.e. Walls, Normal - As Built) and make sure that wall is assigned to that layer set, and then put the new wall in the Walls, Normal - Remodeled layer, then create a view that switches between the two in order to accurately visualize? Edited February 27, 2024 by DIYJon Typo Link to comment Share on other sites More sharing options...
ValleyGuy Posted February 28, 2024 Share Posted February 28, 2024 19 hours ago, DIYJon said: I've watched the video on overlaying a remodel on an as-built plan to visualize the changes, but I think I might be stuck on one point. I have drawn out my current residence. Some of the existing walls are block wall with 1" furring strips between 1/2" drywall with no insulation. I'm furring out those walls to have 2X3 studs and foam insulation. On my as-built plan, will I need to create a new layer just for that wall (i.e. Walls, Normal - As Built) and make sure that wall is assigned to that layer set, and then put the new wall in the Walls, Normal - Remodeled layer, then create a view that switches between the two in order to accurately visualize? You are on the right path, I'm sure there are many ways to accomplish what you are after. I use a combination of layer sets as well as using the reference displays from "As-Built", "Addition Only" and "Completed Project" plans. I also utilize the framing materials for each of the different walls so 3D also has a demo / reno reference. CA has pretty good tools to work with and I've had good feedback from the contractors. Link to comment Share on other sites More sharing options...
