How do I show a cable railing?
cbucks
In the IAMDesign Catalog is some cable railing.  When you are in the railing dialog box, change your railing type to "Panels", then click on the Newel/Baluster tab on the side and under the Panels area click on the library button.  You can type in cable and it should bring up all of your cable railing options.  You can then add top and bottom rails if you prefer and change your newel posts to something appropriate.
